Головной свет - вариант с IQ.Light
A - 14-Pin Connector -T14v-, black / 14-Pin Connector -T14x-, black
1 - Control Module for Adaptive Cruise Control -J428-
2 - Left Horn -H33-
3 - Fiber Optic Cable for Contour Illumination in Left Front Radiator Grille -L363-
4 - Left Front Headlamp -MX1-
5 - Left Front Parking Aid Sensor -G255-
6 - Left Front Center Parking Aid Sensor -G254-
7 - Outside Air Temperature Sensor -G17-
8 - Right Front Center Parking Aid Sensor -G253-
9 - Right Front Parking Aid Sensor -G252-
10 - Right Front Headlamp -MX2-
11 - Fiber Optic Cable for Contour Illumination in Right Front Radiator Grille -L362-
Fiber Optic Cable for Contour Illumination in Left and Right Front Radiator Grille -L362-/-L363-, Removing and Installing
Note: The following information describes the removing and installing on the left side of the vehicle as an example.
Removing
– Switch off the ignition and all electrical equipment.
– Place the ignition key and other drive authorization systems outside of the vehicle interior, to avoid an unintentional start of the vehicle.
– Remove the radiator grille reinforcement.
– Disconnect the connector -2-.
– Remove the bolts -3-.
– Release the clip -4- in the direction of -arrow A-.
– Remove the Fiber Optic Cable for Contour Illumination in Left and Right Front Radiator Grille -L362-/- L363- -1-.
Installing
Install in the reverse order of removal while noting the following:
Tightening Specifications
Component Tightening Specification
Lamp in the Radiator Grille, Bolts.2 Nm
На схемах, если надо, искать:
L362 - Light conductor for contour lighting in radiator grille, front right
L363 - Light conductor for contour lighting in radiator grille, front left
  • vw-taos-wd-12.pdf
    116 КБ · Просмотры: 2,244
  • vw-taos-wd-21.pdf
    81.3 КБ · Просмотры: 757
Клаксон? Так он вообще не там.. он за передним правым подкрылком.
@Servikt , не лазили еще в гриль? Похоже, судя по схеме, фишка стоит прямо сзади полосок, возможно даже через родную решетку можно пальцами ощупать. Только я вот не понял, электрический ли это разъем? Не световод ли? Как то странно он изображен.
100% это не световод, и фишка быть обязана. Не лазил, но полезу в самое ближайшее время - как пленкой буду оклеивать, тогда и попутные все работы будут.
