- 550
- 406
По маслу никаких новостей, все по прежнему 508 для 1,4л и 502 для 1,6л.
29.12.2021
Руководство "Инспекционный сервис и уход»
Код модели: CP13N8
Обозн.двигателя: DJKA
Engine oil: capacities and specifications
A new VW standard for engine oil - 508 00/509 00 - has been introduced for most Volkswagen engines. This is distinguished by reduced fuel
consumption and CO2 emissions.
The main facts are the following:
- VW 508 00/509 00 is a combined product that meets the petrol specification as VW 508 00 and the diesel specification as VW 509 00.
- Volkswagen recommends not using the new specifications for older engine generations. The recommended specifications are allocated to the engines in this chapter.
- If oil with VW engine oil standard 508 00/509 00 is used in engines that are not recommended for this, engine damage could ensue.
- As of model year 2022►, engines in specific markets are equipped with a label (lock carrier/engine compartment) stating the oil standard and viscosity to be used.
- For an overview of the engine oils approved by Volkswagen, see Volkswagen ServiceNet: https://vw.servicenet.vwgroup.com/de/service-technik/inspektion-und-wartung/oelfreigaben.html
З.Ы. Смешно, но выше в таблице высвечивается название модели: Tarek
, хотя запрос по российскому VIN Таоса.
29.12.2021
Код модели: CP13N8
| Модельный год: 2022 Описание модели: Taos RU 1.4 CL G 110TSI A8F Буквенное обозначение КП: UJX |
| Tarek | ||||
| Petrol engines | Oil quantity with filter (I) | VW standard | SAE class | |
| Engine code | Capacity / output | |||
| DJKA | 1.4 l / 110 kW | 4.0 | 508 00 | 0W-20 |
| DWYA | 1.6 l / 81 kW | 4.0 | 502 00 | 5W-40 |
