Руководство VW Taos component locations (расположение компонентов)
VW Taos View from Front
A - 14-Pin Connector -T14v-, black / 14-Pin Connector -T14x-, black
1 - Control Module for Adaptive Cruise Control -J428-
2 - Left Horn -H33-
3 - Fiber Optic Cable for Contour Illumination in Left Front Radiator Grille -L363-
4 - Left Front Headlamp -MX1-
5 - Left Front Parking Aid Sensor -G255-
6 - Left Front Center Parking Aid Sensor -G254-
7 - Outside Air Temperature Sensor -G17-
8 - Right Front Center Parking Aid Sensor -G253-
9 - Right Front Parking Aid Sensor -G252-
10 - Right Front Headlamp -MX2-
11 - Fiber Optic Cable for Contour Illumination in Right Front Radiator Grille -L362-
VW Taos Front, View from Left
A - 14-Pin Connector -T14i-, gray / 14-Pin Connector -T14t-, gray
B - 4-Pin Connector -T4dd-, black /
4-Pin Connector -T4de-, black
Only for vehicles with a 1.4L engine
B - 8-pin connector -T8o-, black / 8-pin connector -T8f-, black
Only for vehicles with 1,5L engine
1 - Left Washer Nozzle Heater -Z20-
2 - Wiper Motor Control Module -J400-
3 - Transmission Control Module -J217-
4 - Left Front ABS Wheel Speed Sensor -G47-
5 - Left Front Level Control System Sensor -G78-
6 - Windshield and Rear Window Washer Pump -V59-
7 - Windshield Washer Fluid Level Sensor -G33-
8 - Engine Coolant Temperature Sensor on Radiator Outlet -G83-
9 - Radiator Fan -VX57-
Only for vehicles with a radiator fan
10 - Engine Hood Contact Switch -F266-
11 - Engine Coolant Level Sensor -G32-
12 - Right Washer Nozzle Heater -Z21-
13 - ABS Control Module -J104-
14 - Battery Monitoring Control Module -J367-
15 - Battery -A-
VW Taos Front, View from Right
A - 6-Pin Connector -T6ab-, black / 6-Pin Connector -T6h-, black
1 - Brake Fluid Level Warning Switch -F34-
2 - Windshield Defogger -Z2-
Left connection
3 - Engine/Motor Control Module -J623-
4 - Driver front airbag crash sensor -G283-
5 - Not used
6 - Radiator Fan -VX57-
7 - Radiator Fan 2 -V177-
Only for vehicles with two radiator fans
8 - Not used
9 - Right Front Brake Pad Wear Sensor -G35-
10 - Right Front ABS Wheel Speed Sensor -G45-
11 - Windshield Defogger -Z2-
12 - Refrigerant Circuit Pressure Sensor -G805-
13 - Power Steering Control Module -J500-
14 - Passenger Side Front Airbag Crash Sensor -G284-
15 - Brake Lamp Switch -F-
16 - Front Airbag Crash Sensor -G190-
Engine 1,4l TFSI DSJA, VW Taos from front
1 - EVAP Canister Purge Regulator Valve 1 -N80-
2 - Fuel Pressure Sensor -G247-
3 - Cylinder 1 Fuel Injector -N30-
4 - Cylinder 2 Fuel Injector -N31-
5 - Cylinder 3 Fuel Injector -N32-
6 - Cylinder 4 Fuel Injector -N33-
7 - Intake Manifold Sensor -GX9-
8 - Charge Air Pressure Sensor -GX26-
9 - Throttle Valve Control Module -GX3-
10 - Engine Speed Sensor -G28-
11 - Charge air cooling pump -V188-
12 - A/C Compressor Regulator Valve -N280-
13 - Knock Sensor 1 -G61-
14 - Generator with Voltage Regulator -CX1-
15 - Reduced Oil Pressure Switch -F378-
Engine 1,4l TFSI DSJA, from top
1 - Intake Manifold Runner Control Valve -N318-
2 - Ignition Coil 1 with Power Output Stage -N70-
3 - Ignition Coil 2 with Power Output Stage -N127-
4 - Not used
5 - Ignition Coil 3 with Power Output Stage -N291-
6 - Not used
7 - Camshaft Position Sensor 3 -G300-
8 - Ignition Coil 4 with Power Output Stage -N292-
9 - Camshaft Position Sensor -G40-
10 - Fuel Pressure Regulator Valve -N276-
11 - Not used
12 - Not used
13 - Camshaft Adjustment Valve 1 -N205-
Engine 1,4l TFSI DSJA from rear
1 - Charge air pressure actuator -V465-
2 - Oxygen Sensor 1 Before Catalytic Converter -GX10-
3 - Oil Pressure Switch -F1-
4 - Oil Pressure Regulation Valve -N428-
5 - Oil Level Thermal Sensor -G266-
6 - Oxygen Sensor 1 After Catalytic Converter -GX7-
7 - Engine Coolant Temperature Sensor -G62-
Engine 1,5l TFSI, DNKA, from front
1 - Activated Charcoal Filter Air Flushing Pressure Sensor -GX44-
2 - EVAP Canister Purge Regulator Valve 1 -N80-
3 - Fuel Pressure Sensor -G247-
4 - Oil pressure sensor -G10-
5 - Cylinder 1 Fuel Injector -N30-
6 - Cylinder 2 Fuel Injector -N31-
7 - Cylinder 3 Fuel Injector -N32-
8 - Cylinder 4 Fuel Injector -N33-
9 - Engine Temperature Control Module -GX33-
11 - Control Unit for Active Oil Separation -J1240-
13 - Generator with Voltage Regulator -CX1-
14 - Knock Sensor 1 -G61-
15 - Charge Air Pressure Sensor -GX26-
Engine 1,5l TFSI, DNKA, from top
1 - Secondary Air Injection Solenoid Valve -N112-
2 - Secondary Air Injection Sensor 1 -G609-
3 - Exhaust Camshaft Position Sensor -G1003-
4 - Exhaust Pressure Sensor 1 -G450-
5 - Fuel metering valve -N290-
6 - Ignition Coil 4 with Power Output Stage -N292-
7 - Ignition Coil 3 with Power Output Stage -N291-
8 - Ignition Coil 2 with Power Output Stage -N127-
9 - Ignition Coil 1 with Power Output Stage -N70-
10 - Intake Camshaft Position Sensor -G1002-
11 - Exhaust Camshaft Adjustment Valve 1 -N318-
Engine 1,5l TFSI, DNKA, from the right
1 - Intake camshaft adjustment valve 1 -N727-
2 - Intake Manifold Sensor -GX9-
3 - Throttle Valve Control Module -GX3-
EPC Throttle Drive -G186-
EPC Throttle Drive Angle Sensor 1 -G187-
EPC Throttle Drive Angle Sensor 2 -G188-
Engine 1,5l TFSI, DNKA, from rear
1 - Oxygen Sensor 1 Before Catalytic Converter -GX10-
2 - Oil Level Thermal Sensor -G266-
3 - Oxygen Sensor 1 After Catalytic Converter -GX7-
4 - Engine Coolant Temperature Sensor on Engine -G82-
5 - Secondary Air Injection Pump Motor -V101-
6 - Engine Coolant Temperature Sensor -G62-
7 - Charge Air Pressure Control Module -GX34-
VW Taos DSG transmission, 0GC
A - 5-Pin Connector -T5o-, Black / 5-Pin Connector -T5t-, Black
1 - Starter -B-
2 - Dual-Clutch Transmission Mechatronic -J743-
3 - Transmission Coolant Valve -N488-
4 - Transmission fluid auxiliary hydraulic pump 1 -V475-
Volkswagen Taos Automatic Transmission 09G
1 - Transmission -NX1-
2 - 10-Pin Connector -T10ai-
3 - 14-Pin Connector -T14-
4 - 8-Pin Connector -T8l-
5 - Starter -B-
Volkswagen Taos Automatic Transmission 09S
2 - Starter -B-
3 - 28-Pin Connector -T28a-
4 - 8-Pin Connector -T8e-
Left Front Interior VW Taos
A - 27-Pin Connector -T27a-, black /
27-Pin Connector -T27b-, black
B - 17-Pin Connector -T17j-, brown /
17-Pin Connector -T17h-, brown
C - 17-Pin Connector -T17e-, blue /
17-Pin Connector -T17m-, blue
D - Steckverbindung, 1-fach -T1in-/
Steckverbindung, 1-fach -T1imE - 17-Pin Connector -T17c-, red /
17-Pin Connector -T17l-, red
F - 17-Pin Connector -T17a-, red /
17-Pin Connector -T17b-, red
G - 3-Pin Connector -T3bl-, yellow /
3-Pin Connector -T3bm-, yellow
H - 19-Pin Connector -T19a-, black /
19-Pin Connector -T19c-, black
1 - Driver Head Curtain Airbag Igniter -N251-
2 - Left Front Treble Speaker -R20-
3 - Digital Sound System Control Module -J525-
4 - Driver Seat Belt Tensioner Igniter 2 -N297-
5 - Driver Seat Belt Tensioner Igniter 1 -N153-
6 - Left front seat belt tensioner control module -J854-
7 - Driver belt force limiter -G551-
8 - Rear Parking Aid Warning Buzzer -H15-
Right Front Interior VW Taos
A - 27-Pin Connector -T27c-, black /
27-Pin Connector -T27d-, black
B - 17-Pin Connector -T17f-, black /
17-Pin Connector -T17o-, black
C - 17-Pin Connector -T17u-, red /
17-Pin Connector -T17p-, red
D - 19-Pin Connector -T19b-, black /
19-Pin Connector -T19d-, black
E - 17-Pin Connector -T17d-, red /
17-Pin Connector -T17v-, red
F - 3-Pin Connector -T3dc-, yellow /
3-Pin Connector -T3de-, yellow
1 - Front Passenger Airbag Igniter 1 -N131-
2 - Front Passenger Head Curtain Airbag Igniter -N252-
3 - Front passenger belt force limiter -G552-
4 - Front Passenger Seat Belt Tensioner Igniter 1 -N154-
5 - Front Passenger Seat Belt Tensioner Igniter 2 -N298-
6 - Access/Start System Interface -J965-
- NAR equipment only
7 - Front Passenger Airbag Deactivation Key Switch -E224-
8 - Instrument Panel Contour Illumination Lamp 3 -L245-
9 - Right Vent Temperature Sensor -G151-
10 - Right Front Treble Speaker -R22-
Instrument panel VW Taos
1 - Emergency Call Module Speaker -R335-
2 - Sunlight photo sensor -G107-
3 - Front Information Display Control Head -J685-
4 - Information Electronics Control Module 1 -J794-
5 - Front Passenger Airbag -Disabled- Indicator Lamp -K145-
6 - Emergency flasher switch -EX3-
7 - Airbag Control Module -J234-
8 - Heater and A/C Controls -EX21-
9 - Instrument Panel Contour Illumination Lamp 2 -L244-
10 - Instrument Cluster -KX2-
Left footwell VW Taos
1 - Left Vent Temperature Sensor -G150-
2 - Rotary Light Switch -EX1-
3 - Instrument Panel Contour Illumination Lamp 1 -L243-
4 - Control Module for Emergency Call Module and Communication Unit -J949-
5 - Data Bus on Board Diagnostic Interface -J533-
6 - Cornering Lamp and Headlamp Range Control Module -J745-
7 - Access/Start System Interface -J965-
- LAM equipment only
8 - Accelerator Pedal Module -GX2-
9 - Parking Aid Control Module -J446-
10 - Vehicle Electrical System Control Module -J519-
11 - Diagnostic Connection -U31-
12 - Front Parking Aid Warning Buzzer -H22
Front center console VW Taos
1 - USB Connection 1 -U41-
2 - 12 V Socket 2 -U18-
3 - Storage Compartment with Cell Phone Interface -R265-
4 - Access/Start System Antenna 1 in Vehicle Interior -R138-
5 - center Console Switch Module 2 -EX30-
6 - Selector mechanism -EX2-
7 - Driving profile selection control head -E881-
8 - Center console switch module 1 -EX23-
9 - Parking brake button -EX12-
10 - Start System Button -E378-
Steering Wheel VW Taos
1 - Steering Column Electronics Control Module -J527-
2 - Driver Airbag Igniter -N95-
3 - Tiptronic Upshift Button on Steering Wheel -E438-
4 - Right Multifunction Buttons on Steering Wheel -E441-
5 - Signal Horn Activation -H-
6 - Steering Wheel Touch Recognition Control Module -J1158-
7 - Tiptronic Downshift Button on Steering Wheel -E439-
8 - Multifunction Steering Wheel Control Module -J453-
9 - Heated Steering Wheel -Z36-
Steering Column VW Taos
2 - Anti-Theft Immobilizer Reader Coil -D2-
Left Front Seat VW Taos
1 - Driver Backrest Adjustment Motor -V45-
2 - Driver seat lumbar support -VX2-
3 - Left Front Seat Backrest Fan 1 -V512-
4 - Driver Thorax Airbag Igniter -N199-
5 - Left Front Seat Adjustment Control Head -EX33-
6 - Driver Seat Lumbar Support Adjustment Switch -E176-
7 - Left Front Seat Cushion Fan 1 -V514-
8 - Driver Seat Forward/Back Adjustment Motor -V28-
9 - Driver seat heating element -Z6-
10 - Driver Seat Belt Switch -E24-
Right Front Seat VW Taos
1 - Front Passenger Thorax Airbag Igniter -N200-
2 - Right Front Seat Backrest Fan 1 -V516-
3 - Front passenger seat lumbar support -VX3-
4 - Front Passenger Backrest Adjustment Motor -V46-
5 - Front Passenger Seat Belt Switch -E25-
6 - Front Passenger Seat Heating Element -Z8-
7 - Passenger Seat Occupant Detection Sensor -G128-
8 - Right Front Seat Cushion Fan 1 -V518-
9 - Passenger Occupant Detection System Control Module -J706-
Rear VW Taos Interior, View from Left
1 - Passenger Side Rear Seat Belt Tensioner Igniter -N197-
2 - Driver Side Rear Seat Belt Tensioner Igniter -N196-
3 - Left Rear ABS Wheel Speed Sensor -G46-
4 - Left Parking Brake Motor -V282-
5 - Driver Side Rear Thorax Airbag Crash Sensor -G256-
6 - Access/Start System Antenna in Luggage Compartment -R137-
7 - Driver Side Second Row Seat Belt Switch -F390-
8 - Center second row seat belt switch -F391-
9 - Passenger Side Second Row Seat Belt Switch -F392-
10 - Passenger Side Rear Thorax Airbag Crash Sensor -G257-
Rear VW Taos, View from Right
A - 6-Pin Connector -T6u-, black / 6-Pin Connector -T6af-, black
Only for AWD vehicles
1 - All Wheel Drive Control Module -J492-
2 - Fuel level sensor 2 -G169-
3 - Fuel Pump Control Module -J538-
4 - Fuel Delivery Unit -GX1-
5 - Right Parking Brake Motor -V283-
6 - Right Rear ABS Wheel Speed Sensor -G44-
Rear Center Console VW Taos
1 - USB Connection 2 -U42-
VW Taos Roof, Section 1
A - 16-Pin Connector -T16e-, brown / 16-Pin Connector -T16g-, brown
1 - Driver Vanity Mirror Lamp -W20-
2 - Driver Vanity Mirror Lamp Contact Switch -F147-
3 - Telephone Microphone -R38-
4 - Driver Assistance Systems Front Camera -R242-
5 - Window Defogger for Front Sensor System -Z113-
6 - Humidity, Rain and Light Recognition Sensor -G823-
7 - Interior Rearview Mirror -EX5-
8 - Front Passenger Vanity Mirror Lamp Contact Switch -F148-
9 - Front Passenger Vanity Mirror Lamp -W14-
10 - Front Interior Lamp -WX1-
11 - Cellular telephone preparation control head -E508-
VW Taos Roof, Section 2
1 - Roof Antenna -RX5-
2 - Rear Interior Lamp -WX2-
3 - Left Rear Interior Lamp -W47- / Right Rear Interior Lamp -W48-
Only for vehicles without a sliding/tilting sunroof
Left Rear Interior Lamp -W47- component location for vehicles with sliding/tilting sunroof ⇒ Item 3
Right Rear Interior Lamp -W48- component location for vehicles with sliding/tilting sunroof ⇒ Item 9
VW Taos Roof, Sliding/Tilting Sunroof, 3FU
A - 6-Pin Connector -T6s-, black / 6-Pin Connector -T6ay-, black
1 - Sunroof Control Module -J245-
2 - Sunroof Shade Motor -V260-
4 - Roof contour illumination lamp 1 -L235-
5 - Sunroof Motor -V1-
6 - Sunroof Button -E325-
7 - Roof Shade Button 1 -E584-
8 - Roof contour illumination lamp 2 -L236-
9 - Right Rear Interior Lamp -W48-
Driver door VW Taos
A - 4-Pin Connector -T4cj-, black / 4-Pin Connector -T4cx-, black
B - 27-Pin Connector -T27a-, black
1 - Driver Side Door Ambient Lighting Lamp -W86-
2 - Driver Interior Locking Button -E308-
3 - Driver Exterior Rearview Mirror -VX4-
4 - Central Locking -Safe- Indicator Lamp -K133-
5 - Driver Door Control Module -J386-
6 - Fuel Filler Door Remote Release Switch -E204-
7 - Left Front Bass Speaker -R21-
8 - Exterior rearview mirror adjuster -EX11-
9 - Power Window Control Head in Driver Door -EX36-
10 - Driver Window Regulator Motor -V147-
11 - Driver Thorax Airbag Crash Sensor -G179-
12 - Driver Door Lock Unit -VX21-
13 - Driver Exterior Door Handle -EX6-
Front passenger door VW Taos
A - 4-pin connector -T4co-, black / 4-pin connector -T4dx-, black
Only for vehicles with access/start authorization system
B - 27-Pin Connector -T27c-, black
1 - Front Passenger Exterior Rearview Mirror -VX5-
2 - Front Passenger Interior Locking Button -E309-
3 - Passenger Side Door Ambient Lighting Lamp -W87-
4 - Front Passenger Exterior Door Handle -EX7-
5 - Front Passenger Door Lock Unit -VX22-
6 - Front Passenger Window Regulator Motor -V148-
7 - Front Passenger Power Window Button -E716-
8 - Front Passenger Thorax Airbag Crash Sensor -G180-
9 - Right Front Bass Speaker -R23-
10 - Front Passenger Door Control Module -J387-
Left Rear Door VW Taos
A - 19-Pin Connector -T19c-, black
1 - Driver Side Rear Power Window Button -E711-
2 - Driver Side Rear Window Regulator Motor -V471-
3 - Left Rear Treble Speaker -R14-
4 - Left Rear Bass Speaker -R15-
5 - Left Rear Door Lock Unit -VX23-
Right Rear Door VW Taos
A - 19-Pin Connector -T19d-, black
1 - Passenger Side Rear Power Window Button -E713-
2 - Passenger Side Rear Window Regulator Motor -V472-
3 - Right Rear Treble Speaker -R16-
4 - Right Rear Bass Speaker -R17-
5 - Right Rear Door Lock Unit -VX24-
Heater and A/C Unit VW Taos
A/C System, Section 1
1 - Recirculation Door Motor -V113-
2 - Fresh Air Blower Control Module -J126-
3 - Fresh Air Blower -V2-
4 - Evaporator Temperature Sensor -G308-
A/C System VW Taos, Section 2
1 - Air Distribution Door -VX33-
2 - Auxiliary Heater Heating Element -Z35-
3 - Temperature control door -VX27-
VW Taos Climatronic, Section 1
1 - Defroster Door -VX47-
2 - Air Recirculation Door -VX52-
3 - Fresh Air Blower Control Module -J126-
4 - Fresh Air Blower -V2-
5 - Right Front Temperature Control Door -VX35-
6 - Evaporator Temperature Sensor -G308-
VW Taos Climatronic, Section 2
2 - Footwell Vent Temperature Sensor -G192-
3 - Rear Temperature Control Door Motor -V137-
4 - Auxiliary Heater Heating Element -Z35-
5 - Left Front Control Temperature Door -VX34-
Rear Lid VW Taos
A - 10-Pin Connector -T10x-, black / 10-Pin Connector -T10h-, black
B - 10-Pin Connector -T10y-, brown / 10-Pin Connector -T10i-, brown
1 - High-Mounted Brake Lamp Bulb -M25-
2 - Right rear window antenna impedance converter -R236-
3 - FM Frequency Filter in Negative Wire -R178-
4 - Right Tail Lamp 2 -MX6-
5 - AM Frequency Filter -R177-
6 - Right License Plate Lamp -X5-
7 - Rear Lid Handle -EX37-
8 - Rear Lid Lock Unit -VX25-
9 - Left License Plate Lamp -X4-
10 - Left Tail Lamp 2 -MX5-
11 - FM Frequency Filter in Positive Wire -R179-
12 - Left rear window antenna impedance converter -R235-
13 - Rear Window Wiper Motor -V12-
Rear bumper VW Taos
A - 8-pin connector -T8l-, black /
8-pin connector -T8n-, black
1 - Right Rear Parking Aid Sensor -G206-
2 - Blind Spot Detection Control Module -J1086-
3 - LTE Antenna 2 -R306-
4 - Right Rear Center Parking Aid Sensor -G205-
5 - Access/Start System Antenna in Rear Bumper -R136-
6 - Left Rear Center Parking Aid Sensor -G204-
7 - Left Rear Parking Aid Sensor -G203-
8 - Blind Spot Detection Control Module 2 -J1087-
Rear, View from Left VW Taos
1 - Luggage Compartment Lamp -W3-
2 - Left Tail Lamp -MX3-
Rear, View from Right VW Taos
A - 10-Pin Connector -T10h-, black / 10-Pin Connector -T10x-, black
Component location in the rear lid ⇒ Item A
B - 10-Pin Connector -T10i-, brown / 10-Pin Connector -T10y-, brown
Component location in the rear lid ⇒ Item B
1 - Fuel Filler Door Unlock -EX13-
2 - Right Tail Lamp -MX4-
3 - Subwoofer -R211-
4 - 12 V Socket -U5-
