- 534
- 401
Fuse holder A -SA- , from May 2021
Fitting location of fuse holder A -SA- , from May 2021
Note: The fuse strip (multifuse) must be replaced as a complete unit.
Fuse assignment for fuse holder A -SA- , from May 2021
1 - Fuse holder A -SA-
Fuse holder B -SB- , from May 2021
Fitting location of fuse holder B -SB- , from May 2021
1 - Fuse holder B -SB-
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat blade fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , from May 2021
1) For models with 1.4l engine
2) For models with 1.6l engine
3) For models with automatic gearbox
4) For models with dual clutch gearbox
5) For models with heated windscreen
6) For models with auxiliary heating
7) For models with no auxiliary heater
8) According to equipment
Fuse holder C -SC- , from May 2021
Fitting location of fuse holder C -SC- , from May 2021
1 - Fuse holder C -SC-
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , from May 2021
1) For models with all-wheel drive
2) For models with background lighting
3) For models with operating unit for driving mode selection
4) For models with heated rear seats
5) For models with anti-theft alarm system
6) For models with parking aid (PDC)
7) For models with electric rear lid opener
8) For models with electric seat adjustment on driver side
9) For models with driver assist systems
10) For models with front camera for driver assist systems
11) For models with emergency call module
12) For models with reversing camera system
13) For models with manual gearbox
14) For models with rain and light sensor
15) For models with seat heating
16) For models with lane change assist
17) For models with headlight range control unit
18) For models with USB charging socket
19) According to equipment
20) See applicable current flow diagram for automatic gearbox
21) See applicable current flow diagram for dual clutch gearbox
Relay and fuse carrier 1 -SR1- , from May 2021
Note: Only models with heated windscreen
Fitting location of relay and fuse carrier 1 -SR1- , from May 2021
Fuse assignment for relay and fuse carrier 1 -SR1- , from May 2021
1) For models with heated windscreen
| Slot | Current flow diagram designation | Nominal value | Function / component | Terminal |
| SA1 | Fuse 1 on fuse holder A -SA1- | 125 A | Fuse holder C -SC- | 30 |
| SA2 | Fuse 2 on fuse holder A -SA2- | 400 A | Alternator with voltage regulator -CX1- | 30 |
| SA3 | Fuse 3 on fuse holder A -SA3- | 80A | Power steering control unit -J500- | 30 |
| SA4 | Fuse 4 on fuse holder A -SA4- | 80A | Fuse holder C -SC- | 30 |
| SA5 | Fuse 5 on fuse holder A -SA5- | 50A | Radiator fan -VX57- | 30 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SB1 | Fuse 1 on fuse holder B -SB1- | 25A | ABS control unit -J104- | 30 |
| SB2 | Fuse 2 on fuse holder B -SB2- | 40A | ABS control unit -J104- | 87 |
| SB3 | Fuse 3 on fuse holder B -SB3- | 15A | Engine/motor control unit -J623- | 87 |
| SB4 | Fuse 4 on fuse holder B -SB4- | 10A | Radiator fan -VX57- Oil level and oil temperature sender -G266- 1) Valve for oil pressure control -N428- 1) Exhaust camshaft control valve 1 -N318- 1) Activated charcoal filter solenoid valve 1 -N80- Camshaft control valve 1 -N205- 1) Engine component current supply relay -J757- 2) Vacuum pump relay -J318- | 87 |
| SB5 | Fuse 5 on fuse holder B -SB5- | 7.5A | Injector, cylinder 1 -N30- 2) Injector, cylinder 2 -N31- 2) Injector, cylinder 3 -N32- 2) Injector, cylinder 4 -N33- 2) | 87 |
| SB6 | Fuse 6 on fuse holder B -SB6- | 7.5A | Brake light switch -F- | 87 |
| SB7 | Fuse 7 on fuse holder B -SB7- | 10A | Charge air cooling pump -V188- 1) | 87 |
| SB8 | Fuse 8 on fuse holder B -SB8- | 10A | Lambda probe 1 after catalytic converter -GX7- Lambda probe 1 before catalytic converter -GX10- | 87 |
| SB9 | Fuse 9 on fuse holder B -SB9- | 20 A | Ignition coil 1 with output stage -N70- Ignition coil 2 with output stage -N127- Ignition coil 3 with output stage -N291- Ignition coil 4 with output stage -N292- | 87 |
| SB10 | Fuse 10 on fuse holder B -SB10- | 15A | Engine component current supply relay -J757- 2) Fuel pump control unit -J538- 1) Fuel delivery unit -GX1- 2) | 87 |
| SB11 | not assigned | - | - | |
| SB12 | not assigned | - | - | |
| SB13 | Fuse 13 on fuse holder B -SB13- | 30A | Auxiliary hydraulic pump 1 for gearbox oil -V475- 4) | 30 |
| SB14 | Fuse 14 on fuse holder B -SB14- | 40A | Heated windscreen -Z2- 5) | 87 |
| SB15 | Fuse 15 on fuse holder B -SB15- | 15A | Horn relay -J413- Treble horn -H2- | 30 |
| SB16 | not assigned | - | - | |
| SB17 | Fuse 17 on fuse holder B -SB17- | 7.5A | ABS control unit -J104- Main relay -J271- Engine/motor control unit -J623- | 30 |
| SB18 | Fuse 18 on fuse holder B -SB18- | 7.5A | Data bus diagnostic interface -J533- 7) Battery monitor control unit -J367- 6) | 30 |
| SB19 | Fuse 19 on fuse holder B -SB19- | 30A | Wiper motor relay 2 -J369- Wiper motor relay 1 -J368- Wiper motor control unit -J400- | 30 |
| SB20 | not assigned | - | 30 | |
| SB21 | Fuse 21 on fuse holder B -SB21- | 15A | Mechatronic unit for dual clutch gearbox -J743- 4) Automatic gearbox control unit -J217- 3) | 30 |
| SB22 | Fuse 22 on fuse holder B -SB22- | 7.5A | Engine/motor control unit -J623- | 50 |
| SB23 | Fuse 23 on fuse holder B -SB23- | 30A | Starter -B- | 50 |
| SB24 | Fuse 24 on fuse holder B -SB24- | 30A | Heated windscreen -Z2- 5) | 87 |
| SB25 | not assigned | - | - | |
| SB26 | not assigned | - | - | |
| SB27 | not assigned | - | - | |
| SB28 | not assigned | - | - | |
| SB29 | not assigned | - | - | |
| SB30 | not assigned | - | - | |
| SB31 | not assigned | - | - | |
| SB32 | not assigned | - | - | |
| SB33 | Fuse 33 on fuse holder B -SB33- | 25A | Front left headlight -MX1- 8) Auxiliary heater control unit -J364- 6) Front right headlight -MX2- 8) | 30 |
| SB34 | not assigned | - | - | |
| SB35 | not assigned | - | - | |
| SB36 | Fuse 36 on fuse holder B -SB36- | 15A | Front left headlight -MX1- 8) | 30 |
| SB37 | Fuse 37 on fuse holder B -SB37- | 20A | Auxiliary heater control unit -J364- 6) | 30 |
| SB38 | Fuse 38 on fuse holder B -SB38- | 15A | Front right headlight -MX2- 8) | 30 |
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
| SC1 | not assigned | - | - | |
| SC2 | Fuse 2 on fuse holder C -SC2- | 10A | Steering column electronics control unit -J527- | 30 |
| SC3 | not assigned | - | - | |
| SC4 | not assigned | - | - | |
| SC5 | Fuse 5 on fuse holder C -SC5- | 7.5A | Data bus diagnostic interface -J533- | 30 |
| SC6 | Fuse 6 on fuse holder C -SC6- | 7.5A | Selector mechanism -EX2- 20), 21) | 30 |
| SC7 | Fuse 7 on fuse holder C -SC7- | 10A | Heater and air conditioning controls -EX21- Heated rear window relay -J9- | 30 |
| SC8 | Fuse 8 on fuse holder C -SC8- | 7.5A | Diagnostic connection -U31- Anti-theft alarm sensor -G578- 5) Rain and light sensor -G397- 14) Light for passenger door background lighting -W87- 2) Light 1 for dash panel contour lighting -L243- 2) Control unit for cornering light and headlight range control -J745- 17) Light 2 for dash panel contour lighting -L244- 2) Light for driver door background lighting -W86- 2) Light 3 for dash panel contour lighting -L245- 2) Driving mode selection button -E735- 3) Parking brake button -EX12- Rotary light switch -EX1- | 30 |
| SC9 | Fuse 9 on fuse holder C -SC9- | 7.5A | Steering column electronics control unit -J527- | 30 |
| SC10 | not assigned | - | - | |
| SC11 | Fuse 11 on fuse holder C -SC11- | 40A | Onboard supply control unit -J519- | 30 |
| SC12 | Fuse 12 on fuse holder C -SC12- | 20A | Control unit 1 for information electronics -J794- 19) | 30 |
| SC13 | not assigned | - | - | |
| SC14 | Fuse 14 on fuse holder C -SC14- | 40A | Fresh air blower control unit -J126- | 30 |
| SC15 | Fuse 15 on fuse holder C -SC15- | 10A | Control unit for electronic steering column lock -J764- | 30 |
| SC16 | Fuse 16 on fuse holder C -SC16- | 7.5A | USB connection 1 -U41- | 30 |
| SC17 | Fuse 17 on fuse holder C -SC17- | 7.5A | Dash panel insert -KX2- Emergency call module control unit and communication unit -J949- 11) | 30 |
| SC18 | Fuse 18 on fuse holder C -SC18- | 7.5A | Rear lid handle -EX37- 12) | 30 |
| SC19 | Fuse 19 on fuse holder C -SC19- | 7.5A | Interface for entry and start system -J965- | 30 |
| SC20 | Fuse 20 on fuse holder C -SC20- | 15A | Vacuum pump relay -J318- Vacuum pump for brakes -V192- | 87 30 |
| SC21 | Fuse 21 on fuse holder C -SC21- | 15A | All-wheel drive control unit -J492- 1) | 30 |
| SC22 | not assigned | - | - | |
| SC23 | not assigned | - | - | |
| SC24 | Fuse 24 on fuse holder C -SC24- | 40A | Onboard supply control unit -J519- | 30 |
| SC25 | Fuse 25 on fuse holder C -SC25- | 30A | Driver door control unit -J386- Rear driver side window regulator motor -V471- | 30 |
| SC26 | Fuse 26 on fuse holder C -SC26- | 30A | Onboard supply control unit -J519- 15) | 30 |
| SC27 | Fuse 27 on fuse holder C -SC27- | 30A | Onboard supply control unit -J519- | 30 |
| SC28 | not assigned | - | - | |
| SC29 | not assigned | - | - | |
| SC30 | not assigned | - | - | |
| SC31 | Fuse 31 on fuse holder C -SC31- | 30A | Rear lid control unit -J605- 7) | 30 |
| SC32 | Fuse 32 on fuse holder C -SC32- | 7.5A | Adaptive cruise control unit -J428- 9) Parking aid control unit -J446- 6) Lane change assist control unit -J769- 16) Lane change assist control unit 2 -J770- 16) Front camera for driver assist systems -R242- 10) | 15 |
| SC33 | Fuse 33 on fuse holder C -SC33- | 7.5A | Airbag control unit -J234- Warning lamp for airbag deactivated on front passenger side -K145- | 15 |
| SC34 | Fuse 34 on fuse holder C -SC34- | 7.5A | Relay for power sockets -J807- Rotary light switch -EX1- Pressure sender for refrigerant circuit -G805- Reversing light switch -F4- 13) Heated rear seats control unit -J786- 4) Parking brake button -EX12- Interior mirror -EX5- | 15 |
| SC35 | Fuse 35 on fuse holder C -SC35- | 7.5A | Diagnostic connection -U31- | 15 |
| SC36 | not assigned | - | - | |
| SC37 | not assigned | - | - | |
| SC38 | not assigned | - | - | |
| SC39 | Fuse 39 on fuse holder C -SC39- | 30A | Rear passenger side window regulator motor -V472- Front passenger door control unit -J387- | 30 |
| SC40 | Fuse 40 on fuse holder C -SC40- | 20A | 12 V socket 2 -U18- | 15 |
| SC41 | not assigned | - | - | |
| SC42 | Fuse 42 on fuse holder C -SC42- | 40A | Onboard supply control unit -J519- | 30 |
| SC43 | not assigned | - | - | |
| SC44 | not assigned | - | - | |
| SC45 | Fuse 45 on fuse holder C -SC45- | 15A | Driver seat lumbar support adjustment switch -E176- 8) Operating unit for front left seat adjustment -EX33- 8) | 30 |
| SC46 | Fuse 46 on fuse holder C -SC46- | 7.5A | USB charging socket 1 -U37- 18) USB charging socket in headlining -U104- 10) | 15 |
| SC47 | Fuse 47 on fuse holder C -SC47- | 15A | Rear window wiper motor -V12- | 15 |
| SC48 | not assigned | - | - | |
| SC49 | Fuse 49 on fuse holder C -SC49- | 7.5A | Starter relay 1 -J906- Starter relay 2 -J907- Clutch position sender -G476- 13) | 15 |
| SC50 | not assigned | - | - | |
| SC51 | Fuse 51 on fuse holder C -SC51- | 25A | Heated rear seats control unit -J786- 4) | 30 |
| SC52 | not assigned | - | - | |
| SC53 | Fuse 53 on fuse holder C -SC53- | 30A | Amplitude modulation (AM) frequency filter -R177- | 15 |
| A | Fuse 24 on fuse holder B -SB24- | 30A | Heated windscreen -Z2- 1) | 87 |
