Руководство Fuses VW Taos
Fuse holder A -SA- , from May 2021
Fitting location of fuse holder A -SA- , from May 2021
Note: The fuse strip (multifuse) must be replaced as a complete unit.
Fuse assignment for fuse holder A -SA- , from May 2021
1 - Fuse holder A -SA-
SlotCurrent flow diagram designationNominal
value
Function / componentTerminal
SA1Fuse 1 on fuse holder A -SA1-125 AFuse holder C -SC-30
SA2Fuse 2 on fuse holder A -SA2-400 AAlternator with voltage regulator -CX1-30
SA3Fuse 3 on fuse holder A -SA3-80APower steering control unit -J500-30
SA4Fuse 4 on fuse holder A -SA4-80AFuse holder C -SC-30
SA5Fuse 5 on fuse holder A -SA5-50ARadiator fan -VX57-30
Fuse holder B -SB- , from May 2021
Fitting location of fuse holder B -SB- , from May 2021
1 - Fuse holder B -SB-
Fuse colours for J-Case fuse:
50 A - red
40 A - green
30 A - pink
Fuse colours for ATO flat blade fuse:
40 A - orange
30 A - light green
25 A - natural (white)
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder B -SB- , from May 2021
value
SB1Fuse 1 on fuse holder B -SB1-25AABS control unit -J104-30
SB2Fuse 2 on fuse holder B -SB2-40AABS control unit -J104-87
SB3Fuse 3 on fuse holder B -SB3-15AEngine/motor control unit -J623-87
SB4Fuse 4 on fuse holder B -SB4-10ARadiator fan -VX57-
Oil level and oil temperature sender -G266- 1)
Valve for oil pressure control -N428- 1)
Exhaust camshaft control valve 1 -N318- 1)
Activated charcoal filter solenoid valve 1 -N80-
Camshaft control valve 1 -N205- 1)
Engine component current supply relay -J757- 2)
Vacuum pump relay -J318-
87
SB5Fuse 5 on fuse holder B -SB5-7.5AInjector, cylinder 1 -N30- 2)
Injector, cylinder 2 -N31- 2)
Injector, cylinder 3 -N32- 2)
Injector, cylinder 4 -N33- 2)
87
SB6Fuse 6 on fuse holder B -SB6-7.5ABrake light switch -F-87
SB7Fuse 7 on fuse holder B -SB7-10ACharge air cooling pump -V188- 1)87
SB8Fuse 8 on fuse holder B -SB8-10ALambda probe 1 after catalytic converter -GX7-
Lambda probe 1 before catalytic converter -GX10-
87
SB9Fuse 9 on fuse holder B -SB9-20
A
Ignition coil 1 with output stage -N70-
Ignition coil 2 with output stage -N127-
Ignition coil 3 with output stage -N291-
Ignition coil 4 with output stage -N292-
87
SB10Fuse 10 on fuse holder B -SB10-15AEngine component current supply relay -J757- 2)
Fuel pump control unit -J538- 1)
Fuel delivery unit -GX1- 2)
87
SB11not assigned--
SB12not assigned--
SB13Fuse 13 on fuse holder B -SB13-30AAuxiliary hydraulic pump 1 for gearbox oil -V475- 4)30
SB14Fuse 14 on fuse holder B -SB14-40AHeated windscreen -Z2- 5)87
SB15Fuse 15 on fuse holder B -SB15-15AHorn relay -J413-
Treble horn -H2-
30
SB16not assigned--
SB17Fuse 17 on fuse holder B -SB17-7.5AABS control unit -J104-
Main relay -J271-
30
SB18Fuse 18 on fuse holder B -SB18-7.5AData bus diagnostic interface -J533- 7)
Battery monitor control unit -J367- 6)
30
SB19Fuse 19 on fuse holder B -SB19-30AWiper motor relay 2 -J369-
Wiper motor relay 1 -J368-
Wiper motor control unit -J400-
30
SB20not assigned-30
SB21Fuse 21 on fuse holder B -SB21-15AMechatronic unit for dual clutch gearbox -J743- 4)
Automatic gearbox control unit -J217- 3)
30
SB22Fuse 22 on fuse holder B -SB22-7.5AEngine/motor control unit -J623-50
SB23Fuse 23 on fuse holder B -SB23-30AStarter -B-50
SB24Fuse 24 on fuse holder B -SB24-30AHeated windscreen -Z2- 5)87
SB25not assigned--
SB26not assigned--
SB27not assigned--
SB28not assigned--
SB29not assigned--
SB30not assigned--
SB31not assigned--
SB32not assigned--
SB33Fuse 33 on fuse holder B -SB33-25AFront left headlight -MX1- 8)
Auxiliary heater control unit -J364- 6)
Front right headlight -MX2- 8)
30
SB34not assigned--
SB35not assigned--
SB36Fuse 36 on fuse holder B -SB36-15AFront left headlight -MX1- 8)30
SB37Fuse 37 on fuse holder B -SB37-20AAuxiliary heater control unit -J364- 6)30
SB38Fuse 38 on fuse holder B -SB38-15AFront right headlight -MX2- 8)30
1) For models with 1.4l engine
2) For models with 1.6l engine
3) For models with automatic gearbox
4) For models with dual clutch gearbox
5) For models with heated windscreen
6) For models with auxiliary heating
7) For models with no auxiliary heater
8) According to equipment
Fuse holder C -SC- , from May 2021
Fitting location of fuse holder C -SC- , from May 2021
1 - Fuse holder C -SC-
50 A - red
40 A - green
30 A - pink
40 A - orange
30 A - light green
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse colours, for mini fuses:
20 A - yellow
15 A - light blue
10 A - red
7.5 A - brown
5 A - light brown
1 A - black
Fuse assignment for fuse holder C -SC- , from May 2021
value
SC1not assigned--
SC2Fuse 2 on fuse holder C -SC2-10ASteering column electronics control unit -J527-30
SC3not assigned--
SC4not assigned--
SC5Fuse 5 on fuse holder C -SC5-7.5AData bus diagnostic interface -J533-30
SC6Fuse 6 on fuse holder C -SC6-7.5ASelector mechanism -EX2- 20), 21)30
SC7Fuse 7 on fuse holder C -SC7-10AHeater and air conditioning controls -EX21-
Heated rear window relay -J9-
30
SC8Fuse 8 on fuse holder C -SC8-7.5ADiagnostic connection -U31-
Anti-theft alarm sensor -G578- 5)
Rain and light sensor -G397- 14)
Light for passenger door background lighting -W87- 2)
Light 1 for dash panel contour lighting -L243- 2)
Control unit for cornering light and headlight range control -J745- 17)
Light 2 for dash panel contour lighting -L244- 2)
Light for driver door background lighting -W86- 2)
Light 3 for dash panel contour lighting -L245- 2)
Driving mode selection button -E735- 3)
Parking brake button -EX12-
Rotary light switch -EX1-
30
SC9Fuse 9 on fuse holder C -SC9-7.5ASteering column electronics control unit -J527-30
SC10not assigned--
SC11Fuse 11 on fuse holder C -SC11-40AOnboard supply control unit -J519-30
SC12Fuse 12 on fuse holder C -SC12-20AControl unit 1 for information electronics -J794- 19)30
SC13not assigned--
SC14Fuse 14 on fuse holder C -SC14-40AFresh air blower control unit -J126-30
SC15Fuse 15 on fuse holder C -SC15-10AControl unit for electronic steering column lock -J764-30
SC16Fuse 16 on fuse holder C -SC16-7.5AUSB connection 1 -U41-30
SC17Fuse 17 on fuse holder C -SC17-7.5ADash panel insert -KX2-
Emergency call module control unit and communication
unit -J949- 11)
30
SC18Fuse 18 on fuse holder C -SC18-7.5ARear lid handle -EX37- 12)30
SC19Fuse 19 on fuse holder C -SC19-7.5AInterface for entry and start system -J965-30
SC20Fuse 20 on fuse holder C -SC20-15AVacuum pump relay -J318-
Vacuum pump for brakes -V192-
87
30
SC21Fuse 21 on fuse holder C -SC21-15AAll-wheel drive control unit -J492- 1)30
SC22not assigned--
SC23not assigned--
SC24Fuse 24 on fuse holder C -SC24-40AOnboard supply control unit -J519-30
SC25Fuse 25 on fuse holder C -SC25-30ADriver door control unit -J386-
Rear driver side window regulator motor -V471-
30
SC26Fuse 26 on fuse holder C -SC26-30AOnboard supply control unit -J519- 15)30
SC27Fuse 27 on fuse holder C -SC27-30AOnboard supply control unit -J519-30
SC28not assigned--
SC29not assigned--
SC30not assigned--
SC31Fuse 31 on fuse holder C -SC31-30ARear lid control unit -J605- 7)30
SC32Fuse 32 on fuse holder C -SC32-7.5AAdaptive cruise control unit -J428- 9)
Parking aid control unit -J446- 6)
Lane change assist control unit -J769- 16)
Lane change assist control unit 2 -J770- 16)
Front camera for driver assist systems -R242- 10)
15
SC33Fuse 33 on fuse holder C -SC33-7.5AAirbag control unit -J234-
Warning lamp for airbag deactivated on front passenger
side -K145-
15
SC34Fuse 34 on fuse holder C -SC34-7.5ARelay for power sockets -J807-
Pressure sender for refrigerant circuit -G805-
Reversing light switch -F4- 13)
Heated rear seats control unit -J786- 4)
Interior mirror -EX5-
15
SC35Fuse 35 on fuse holder C -SC35-7.5ADiagnostic connection -U31-15
SC36not assigned--
SC37not assigned--
SC38not assigned--
SC39Fuse 39 on fuse holder C -SC39-30ARear passenger side window regulator motor -V472-
Front passenger door control unit -J387-
30
SC40Fuse 40 on fuse holder C -SC40-20A12 V socket 2 -U18-15
SC41not assigned--
SC42Fuse 42 on fuse holder C -SC42-40AOnboard supply control unit -J519-30
SC43not assigned--
SC44not assigned--
SC45Fuse 45 on fuse holder C -SC45-15ADriver seat lumbar support adjustment switch -E176- 8)
Operating unit for front left seat adjustment -EX33- 8)
30
SC46Fuse 46 on fuse holder C -SC46-7.5AUSB charging socket 1 -U37- 18)
USB charging socket in headlining -U104- 10)
15
SC47Fuse 47 on fuse holder C -SC47-15ARear window wiper motor -V12-15
SC48not assigned--
SC49Fuse 49 on fuse holder C -SC49-7.5AStarter relay 1 -J906-
Starter relay 2 -J907-
Clutch position sender -G476- 13)
15
SC50not assigned--
SC51Fuse 51 on fuse holder C -SC51-25AHeated rear seats control unit -J786- 4)30
SC52not assigned--
SC53Fuse 53 on fuse holder C -SC53-30AAmplitude modulation (AM) frequency filter -R177-15
1) For models with all-wheel drive
2) For models with background lighting
3) For models with operating unit for driving mode selection
4) For models with heated rear seats
5) For models with anti-theft alarm system
6) For models with parking aid (PDC)
7) For models with electric rear lid opener
8) For models with electric seat adjustment on driver side
9) For models with driver assist systems
10) For models with front camera for driver assist systems
11) For models with emergency call module
12) For models with reversing camera system
13) For models with manual gearbox
14) For models with rain and light sensor
15) For models with seat heating
16) For models with lane change assist
17) For models with headlight range control unit
18) For models with USB charging socket
19) According to equipment
20) See applicable current flow diagram for automatic gearbox
21) See applicable current flow diagram for dual clutch gearbox
Relay and fuse carrier 1 -SR1- , from May 2021
Note: Only models with heated windscreen
Fitting location of relay and fuse carrier 1 -SR1- , from May 2021
Fuse assignment for relay and fuse carrier 1 -SR1- , from May 2021
value
AFuse 24 on fuse holder B -SB24-30AHeated windscreen -Z2- 1)87
1) For models with heated windscreen
P.S. Информация именно для российских Таосов, не для мексиканских / аргентинских,
у них другое расположение предохранителей...
Предохранители и реле для:
Volkswagen Taos Mex (CL1) 2021 -
Volkswagen Taos Arg (CQ1) 2021 -
