Руководство VW Taos Heating, Ventilation and Air Conditioning - Repair manual
VW Taos Mex 2021 ➤
Heating, Ventilation and Air Conditioning (eng.) Repair manual
Edition 05.2021
Contents:
00 - General, Technical Data
1 Safety Precautions
1.1 Safety Precautions when Working on A/C Systems
1.2 Safety Precautions when Handling Refrigerant
1.3 Safety Precautions when Working on Vehicles with Start/Stop System
1.4 Safety Precautions when Working on Cooling System
1.5 Safety Precautions when Working on Vehicles with Parking/Auxiliary Heater (Not for North American Market)
1.6 Safety Precautions during Road Test with Testing Equipment
2 Identification
2.1 Heater and A/C Unit Identification
3 General Information
3.1 Odors in Vehicles with A/C System Information
3.2 Information for Vehicles with Start/Stop System
3.3 Type Labels
4 Repair Information
4.1 Working on Refrigerant Circuit
4.2 General Repair Information
4.3 Refrigerant Circuit Seals
5 Technical Data
5.1 Refrigerant Capacities
5.2 Refrigerant Oil Capacities
5.3 Oil Distribution
80 - Heating, Ventilation
1 Heating
87 - Air Conditioning
1 Component Location Overview - A/C System
1.1 Component Location Overview - Components Outside of Vehicle Interior
1.2 Component Location Overview - Components in Front Vehicle Interior
2 Refrigerant Circuit
2.1 System Overview - Refrigerant Circuit
2.2 Overview - Condenser
2.3 Refrigerant Circuit Pressure Sensor G805, Removing and Installing
2.4 Expansion Valve, Removing and Installing
2.5 Condenser, Removing and Installing
2.6 Desiccant Bag/Dryer Cartridge, Removing and Installing
2.7 Low Pressure Side Refrigerant Line Balance Weight, Removing and Installing
2.8 Evacuating and Charging Valve, Removing and Installing, Low and High Pressure Side
2.9 Refrigerant Lines with Inner Heat Exchanger, Removing and Installing
2.10 Refrigerant Line from Condenser to Evaporator, Removing and Installing
2.11 Refrigerant Line from A/C Compressor to Condenser, Removing and Installing
2.12 Refrigerant Line from Evaporator to A/C Compressor, Removing and Installing
2.13 A/C System, Starting after Charging Refrigerant Circuit
3 A/C Compressor
3.1 Overview - A/C Compressor
3.2 Overview - Belt Pulley
3.3 A/C Compressor, Removing and Installing on Bracket
3.4 A/C Compressor, Removing and Installing
3.5 Pressure Relief Valve on A/C Compressor, Checking
3.6 Belt Pulley, Removing and Installing
4 Actuators
4.1 Component Location Overview - Front Actuators
4.2 Temperature Control Door Motor V68, Removing and Installing
4.3 Defroster Door Motor V107, Removing and Installing
4.4 Recirculation Door Motor V113, Removing and Installing
4.5 Left Temperature Control Door Motor V158, Removing and Installing
4.6 Right Temperature Control Door Motor V159, Removing and Installing
4.7 Fresh Air/Recirculating Air/Back Pressure Door Motor V425, Removing and Installing
4.8 Front Air Distribution Door Motor V426, Removing and Installing
4.9 Air Distribution Door Motor V428, Removing and Installing
4.10 Air Distribution Door Adjusting Unit, Removing and Installing
5 Front Heater and A/C Unit
5.1 Overview - Heater and A/C Unit
5.2 Overview - Attachments for Heater and A/C Unit and Air Intake Manifold
5.3 Overview - Evaporator Housing
5.4 Overview - Air Distribution Housing Doors and Separators
5.5 Heater and A/C Unit, Removing and Installing
5.6 Heater and A/C Unit, Disassembling and Assembling
5.7 Air Distribution Housing, Removing and Installing
5.8 Heater and A/C Unit Bracket, Removing and Installing
5.9 Evaporator, Removing and Installing
5.10 Fresh Air Blower Control Module J126, Removing and Installing
5.11 Dust and Pollen Filter, Removing and Installing
5.12 Fresh Air Blower V2, Removing and Installing
5.13 Auxiliary Heater Heating Element Z35, Checking
5.14 Auxiliary Heater Heating Element Z35, Removing and Installing
5.15 Heater Core, Removing and Installing
5.16 Heater Core Coolant Pipes, Removing and Installing
5.17 Evaporator Temperature Sensor G308, Removing and Installing
5.18 Condensation Water Drain, Checking
5.19 Condensation Water Drain, Removing and Installing
5.20 Partition, Removing and Installing
6 Air Duct
6.1 Overview - Air Routing and Air Distribution in Vehicle Interior
6.2 Fresh Air Intake, Removing and Installing
6.3 Fresh Air Intake Cover, Removing and Installing
6.4 Air Intake Duct, Removing and Installing
6.5 Driver Side Footwell Vent, Removing and Installing
6.6 Front Passenger Side Footwell Vent, Removing and Installing
6.7 Rear Footwell Vent, Removing and Installing
6.8 Air Duct for Rear Vent, Removing and Installing
6.9 Air Duct for Rear Center Console Vent, Removing and Installing
6.10 Vehicle Interior Forced Air Extraction, Checking
6.11 Vehicle Interior Forced Air Extraction, Removing and Installing
6.12 Air Duct for Defrost Air Vent, Removing and Installing
6.13 Center Instrument Panel Vent Air Duct, Removing and Installing
7 Display Control Head
7.1 Overview - Display Control Head
7.2 Front Display and Control Head, Removing and Installing
8 Additional Components for Control and Regulation
8.1 Sunlight Photo Sensor G107, Removing and Installing
8.2 Air Quality Sensor G238, Removing and Installing
8.3 Outside Air Temperature Sensor G17, Removing and Installing
8.4 A/C Humidity Sensor G260, Removing and Installing
8.5 Left Vent Temperature Sensor G150, Removing and Installing
8.6 Right Vent Temperature Sensor G151, Removing and Installing
8.7 Footwell Vent Temperature Sensor G192, Removing and Installing
