Руководство VW Taos Fuel Supply - Gasoline Engines - Repair manual
VW Taos Arg 2021 ➤
VW Taos Mex 2021 ➤
Fuel Supply - Gasoline Engines (eng.) Repair manual
Engine code: CWLA, DNKA, DSJA
Edition 05.2021
Contents:
00 - General, Technical Data
1 Safety Precautions
1.1 Safety Precautions when Working on Fuel Supply System
1.2 Safety Precautions during Road Test with Testing Equipment
1.3 Safety Precautions when Working on Vehicles with Start/Stop System
2 Identification
2.1 Engine Number/Engine Specifications
3 General Information
3.1 Guidelines for Clean Working Conditions on Parking/Auxiliary Heater and Fuel System
4 Repair Information
4.1 Line Routing and Securing
4.2 General Repair Information
20 - Fuel Supply
1 Fuel Tank
1.1 Overview - Fuel Tank
1.2 Fuel Tank, Removing and Installing
1.3 Fuel Tank, Draining
2 Fuel Delivery Unit/Fuel Level Sensor
2.1 Overview - Fuel Delivery Unit/Fuel Level Sensor
2.2 Fuel Delivery Unit/Fuel Level Sensor, Removing and Installing
2.3 Fuel Level Sensor G, Removing and Installing
2.4 Fuel Level Sensor 2 G169, Removing and Installing
2.5 Installation Opening Cover, Removing and Installing
3 Connector Couplings
3.1 Connector Couplings, Disconnecting
4 Fuel Filter
4.1 Overview - Fuel Filter
4.2 Fuel Filter, Removing and Installing
5 EVAP System
5.1 Connection Diagram - EVAP System
5.2 Overview - EVAP System
5.3 EVAP Canister, Removing and Installing
5.4 Leak Detection Pump, Removing and Installing
5.5 EVAP Canister Air Filter, Removing and Installing, with Fuel Tank Leak Detection Module GX36 and Fuel Tank Shut-Off Valve
5.6 Pressure Regulating Valve with Fuel Tank Pressure Sensor G400, Removing and Installing
5.7 Fuel Tank Bleeding, Checking, Vehicles without Fuel Tank Leak Detection
5.8 Fuel System, Checking for Leaks
6 Accelerator Mechanism
6.1 Overview - Accelerator Pedal Module
6.2 Accelerator Pedal Module GX2, Removing and Installing
7 Fuel Pump
7.1 Transfer Fuel Pump G6, Checking
7.2 Suction Jet Pump, Removing and Installing
7.3 Fuel Pump Control Module J538, Removing and Installing
7.4 Suction Jet Pump, Checking
8 Fuel Lines
8.1 Fuel Lines, Removing and Installing
