- 454
- 373
Service tables VW Taos
Deviating scopes of service no longer include extended additional inspections. These must now also be carried out within the scope of every inspection.
Deviating service intervals: inspection is now always due after the same interval, meaning e.g. for PR-number QI4: after 30,000 km or 2 years, whichever occurs first.
Individual intervals of the additional work have been adapted to the new inspection interval.
Delivery inspection
Service intervals VW Taos
1) Whichever occurs first.
Air filter VW Taos
Interior filter VW Taos
Toothed belt VW Taos
Engines with toothed belts that have no prescribed replacement or inspection interval are engineered to last longer.
Volkswagen recommends an inspection of the toothed belt after 300,000 km or 15 years.
Poly V-belt VW Taos
1) Engines equipped with a belt-driven starter-alternator are listed in the engine overview
Spark plugs VW Taos
Brake fluid VW Taos
Automatic gearbox VW Taos
Multi-purpose additive VW Taos
Country-specific additional work dependent on time and mileage VW Taos
Delivery inspection
Scope of work |
Diagnostic work |
- Transportation mode: switch off. |
- Status of 12V battery: read. • Runs automatically on vehicles with battery monitor control unit -367- at switching off of transportation mode. |
- 12V battery: check using -VAS 6161-. • Only applicable to vehicles without battery data module. |
- Service interval display: reset. |
- Event memories of all systems: read. |
Vehicle interior |
- Front passenger airbag: check key switch and ON/OFF function. |
- Vehicle interior: check for cleanliness. |
- All switches, electrical consumers, sockets, gauges and other control elements: check function |
- Window regulators: initialise (activate). |
- Time and date: set. |
- Two safety hammers: install according to installation instructions. • Applies only to the Netherlands. |
- High-voltage battery: check charge level (recommendation: approx. 80% when handing over to customer) • Applies only to BEV and PHEV |
Vehicle exterior |
- Vehicle exterior: check for cleanliness. |
- Wheel bolts: tighten to specified torque. |
- Wiper blade protection: remove. |
Underside of vehicle |
- Vehicle underside (underbody): inspect for damage. |
- Brake system: inspect for leaks and damage. |
- Transportation devices: remove (if fitted). |
- Vehicle underside: inspect for leaks and damage. |
Tyres |
- Tyre pressure: check. |
Engine compartment |
- Coolant level: check. |
- Engine oil level: check; observe oil specification when topping up. |
- Brake fluid level: check that it is at maximum. |
- Brake fluid: renew, if vehicle is older than 12 months. |
- Windscreen wash/wipe system and headlight washer system: check function and settings. |
Concluding work |
- 12V battery: check battery clamp for firm seating. |
- All equipment which has been packed inside vehicle (if part of original equipment): install. |
- Tyre Pressure Loss Indicator: calibrate after tyre pressure has been corrected. |
- Keys: check number, operation and cleanliness. |
- Service Schedule / Digital Service Schedule: enter pre-delivery inspection. |
- Road test vehicle. |
- Charging cable: check that cable is present and check its condition. • Applies only to BEV and PHEV |
Scope of work | Climate and traffic conditions usual for passenger vehicles operated on fuels compliant with EN 228 | For operation with fuels that are »NOT« compliant with standard EN 228. |
Oil change service | --- | QI1 every 5,000 km or 1 year (fixed) 1) |
--- | QI2 every 7,500 km or 1 year (fixed) 1) | |
--- | QI3 every 10,000 km or 1 year (fixed) 1) | |
QI4 every 15,000 km or 1 year (fixed) 1) |
Scope of work | Climate and traffic conditions usual for passenger vehicles | For operation with fuels that are NOT compliant with standard EN 228 |
Inspection | Every 30,000 km or 2 years1) | Every 10,000 km or 1 year1) Applies to vehicles with PR numbers QI1 and QI3. Every 15,000 km or 1 year1) Applies to vehicles with PR numbers QI2 and QI4. |
Air filter VW Taos
Scope of work | Climate and traffic conditions usual for passenger vehicles | Countries with high levels of dust |
Air filter: cleaning housing and renewing filter element | Every 90,000 km or 6 years 1) | Every 30,000 km or 2 years 1) |
Interior filter: clean housing and renew filter element | Every 30,000 km or 2 years 1) | Max. 1 year or 30,000 km 1) |
Toothed belt and camshaft drive tensioning roller: renew. • Applies to all petrol engines with toothed belt | --- | Every 120,000 km |
Toothed belt drive for coolant pump: renew. • Applies to all petrol engines with toothed belt for coolant pump | --- | Every 120,000 km |
Poly V-belt VW Taos
Poly V-belt: renewing | --- | Every 60,000 km |
Poly V-belt and tensioning roller for belt-driven starter-alternator: renew 1) | Every 180,000 km | Every 60,000 km |
Spark plugs VW Taos
Scope of work | Petrol engine compliant with EN 228 | E100 | Petrol engine not compliant with EN 228 |
Spark plugs: renewing | Every 60,000 km or 4 years 1) | Every 40,000 km or 4 years 1) | Every 30,000 km / 20,000 km or 2 years 1) and every 15,000 km / 10,000 km or 1 year 1) |
Brake fluid VW Taos
Scope of work | Worldwide |
Brake and clutch system: changing brake fluid | Every 2 years |
Scope of work | Climate and traffic conditions usual for passenger vehicles | Countries with hot climate | North American market |
Automatic gearbox: change ATF. | --- | Every 60,000 km | --- |
Automatic gearbox: change ATF. | --- | --- | Every 80,000 mi |
Scope of work | Climate and traffic conditions usual for passenger vehicles | Russia |
Multi-purpose additive for petrol fuel: adding | --- | At every service. |
Scope of work | Interval |
Dual clutch gearbox (DSG) 0GC: change gear oil. | Every 120,000 km |
All-wheel drive coupling: changing oil | Every 2 years |
