Важно! Service tables VW Taos (переодичность сервисного обслуживания Таос)
Deviating scopes of service no longer include extended additional inspections. These must now also be carried out within the scope of every inspection.
Deviating service intervals: inspection is now always due after the same interval, meaning e.g. for PR-number QI4: after 30,000 km or 2 years, whichever occurs first.
Individual intervals of the additional work have been adapted to the new inspection interval.
Delivery inspection
Scope of work
Diagnostic work
- Transportation mode: switch off.
- Status of 12V battery: read.
• Runs automatically on vehicles with battery monitor control unit -367- at switching off of transportation mode.
- 12V battery: check using -VAS 6161-.
• Only applicable to vehicles without battery data module.
- Service interval display: reset.
- Event memories of all systems: read.
Vehicle interior
- Front passenger airbag: check key switch and ON/OFF function.
- Vehicle interior: check for cleanliness.
- All switches, electrical consumers, sockets, gauges and other control elements: check function
- Window regulators: initialise (activate).
- Time and date: set.
- Two safety hammers: install according to installation instructions.
• Applies only to the Netherlands.
- High-voltage battery: check charge level (recommendation: approx. 80% when handing over to customer)
• Applies only to BEV and PHEV
Vehicle exterior
- Vehicle exterior: check for cleanliness.
- Wheel bolts: tighten to specified torque.
- Wiper blade protection: remove.
Underside of vehicle
- Vehicle underside (underbody): inspect for damage.
- Brake system: inspect for leaks and damage.
- Transportation devices: remove (if fitted).
- Vehicle underside: inspect for leaks and damage.
Tyres
- Tyre pressure: check.
Engine compartment
- Coolant level: check.
- Engine oil level: check; observe oil specification when topping up.
- Brake fluid level: check that it is at maximum.
- Brake fluid: renew, if vehicle is older than 12 months.
- Windscreen wash/wipe system and headlight washer system: check function and settings.
Concluding work
- 12V battery: check battery clamp for firm seating.
- All equipment which has been packed inside vehicle (if part of original equipment): install.
- Tyre Pressure Loss Indicator: calibrate after tyre pressure has been corrected.
- Keys: check number, operation and cleanliness.
- Service Schedule / Digital Service Schedule: enter pre-delivery inspection.
- Road test vehicle.
- Charging cable: check that cable is present and check its condition.
Service intervals VW Taos
Scope of workClimate and traffic conditions usual
for passenger vehicles operated on
fuels compliant with EN 228
For operation with fuels that are »NOT«
compliant with standard EN 228.
Oil change service---QI1
every 5,000 km or 1 year (fixed) 1)
---QI2
every 7,500 km or 1 year (fixed) 1)
---QI3
every 10,000 km or 1 year (fixed) 1)
QI4
every 15,000 km or 1 year (fixed) 1)
1) Whichever occurs first.
usual for passenger vehicles
NOT compliant with standard EN 228
InspectionEvery 30,000 km or
2 years1)
Every 10,000 km or 1 year1)
Applies to vehicles with PR numbers QI1 and QI3.
Every 15,000 km or 1 year1)
Applies to vehicles with PR numbers QI2 and QI4.
Air filter VW Taos
Countries with high levels of dust
Air filter: cleaning housing
and renewing filter element
Every 90,000 km
or 6 years 1)
Every 30,000 km
or 2 years 1)
Interior filter VW Taos
Interior filter: clean housing
and renew filter element
Every 30,000 km
or 2 years 1)
Max. 1 year
or 30,000 km 1)
Toothed belt VW Taos
Toothed belt and camshaft drive tensioning roller: renew.
• Applies to all petrol engines with toothed belt
---Every 120,000 km
Toothed belt drive for coolant pump: renew.
• Applies to all petrol engines with toothed belt for coolant pump
---Every 120,000 km
Engines with toothed belts that have no prescribed replacement or inspection interval are engineered to last longer.
Volkswagen recommends an inspection of the toothed belt after 300,000 km or 15 years.
Poly V-belt VW Taos
Poly V-belt: renewing---Every 60,000 km
Poly V-belt and tensioning roller for
belt-driven starter-alternator: renew 1)
Every 180,000 kmEvery 60,000 km
1) Engines equipped with a belt-driven starter-alternator are listed in the engine overview
Spark plugs VW Taos
Scope of workPetrol engine compliant
with EN 228
E100Petrol engine not compliant
with EN 228
Spark plugs: renewingEvery 60,000 km
or 4 years 1)
Every 40,000 km
or 4 years 1)
Every 30,000 km / 20,000 km or 2 years 1)
and
every 15,000 km / 10,000 km or 1 year 1)
Brake fluid VW Taos
Scope of workWorldwide
Brake and clutch system: changing brake fluidEvery 2 years
Automatic gearbox VW Taos
Countries with hot climateNorth American market
Automatic gearbox: change ATF.---Every 60,000 km---
Automatic gearbox: change ATF.------Every 80,000 mi
Multi-purpose additive VW Taos
Russia
Multi-purpose additive for petrol fuel: adding---At every service.
Country-specific additional work dependent on time and mileage VW Taos
Scope of workInterval
Dual clutch gearbox (DSG) 0GC: change gear oil.Every 120,000 km
All-wheel drive coupling: changing oilEvery 2 years
Всем доброго дня!
Подскажите, уважаемые форумчане, на какой километраж мне ориентироваться для замены ремня ГРМ? Первую сотню разменял...
Передний привод-1.4.
Всем доброго дня!
Выше в посте Admina сказано, что 120 тыс. км (если считать, что машина эксплуатируется в запыленном климате). А разменяли Вы всё-таки вторую сотню: первая "разменивается" сразу при сходе машины с конвейера. :)
Помпа и ролики тоже меняются сразу с ремнем:
Ссылка на пункт 3.11:
Камрады,периодичность от слова период?
