- 551
- 408
Сброс сервисного интервала на приборной панели Фольксваген Таос:
Resetting the service interval display If the service was not performed by an authorized Volkswagen
dealer or an authorized Volkswagen Service Facility, the service reminder can be reset as follows:
Vehicles with analog instrument cluster:
1. Switch the ignition off.
2. Press and hold the 0.0 / SET button in the instrument cluster.
3. Switch the ignition back on.
4. Release the 0.0 / SET button when one of the following messages appears in the instrument cluster display:
"Reset oil change service? or Reset inspection service?"
5. Press the OK button in the instrument cluster to confirm.
Vehicles with a digital instrument cluster:
The service interval display can only be reset through the service menu.
Do »not« reset the service reminder between service intervals;
or incorrect information will be displayed.
If the oil change service was manually reset, the service interval display then also switches to a fixed service interval, even on vehicles with »flexible oil change service«.
