Руководство VW Taos Suspension, Wheels, Steering - Repair manual
VW Taos Arg 2021 ➤
VW Taos Mex 2021 ➤
Suspension, Wheels, Steering (eng.) Repair manual
Edition 03.2021
Contents:
00 - Technical Data
1 Safety Precautions
1.1 Safety Precautions when Working on Vehicles with Start/Stop System
1.2 Safety Precautions when Working on Subframe
2 Vehicles Involved in Collisions, Evaluating
2.1 Collision Vehicle Evaluation Checklist
3 Repair Information
3.1 Shock Absorber Leaks
3.2 Shock Absorber Noises
3.3 Shock Absorbers, Checking when Removed
3.4 Steering Gear
3.5 Seals and Gaskets
3.6 Bolts and Nuts
3.7 Electrical Components
3.8 Wheel Bearing in Curb Weight Position, Lifting Vehicles with Coil Spring
4 Disposal
4.1 Front Gas-Filled Shock Absorbers, Venting and Draining
4.2 Rear Gas-Filled Shock Absorbers, Venting and Draining
5 Special Tools
40 - Front Suspension
1 Front Axle
1.1 Component Location Overview - Front Axle
2 Subframe
2.1 Overview - Subframe
2.2 Subframe without Steering Gear, Removing and Installing
2.3 Subframe with Steering Gear, Removing and Installing
2.4 Subframe, Servicing
2.5 Stabilizer Bar, Removing and Installing
2.6 Coupling Rod, Removing and Installing
2.7 Thread in Longitudinal Member, Servicing
2.8 Subframe, Securing
2.9 Subframe, Lowering
3 Suspension Strut and Upper Control Arm
3.1 Overview - Suspension Strut and Upper Control Arm
3.2 Suspension Strut, Removing and Installing
3.3 Suspension Strut, Servicing
4 Lower Control Arm and Ball Joint
4.1 Overview - Lower Control Arm and Ball Joint
4.2 Lower Control Arm, Removing and Installing
4.3 Ball Joint, Checking
4.4 Ball Joint, Removing and Installing
4.5 Front Lower Control Arm Bonded Rubber Bushing, Replacing
4.6 Lower Control Arm Rear Bonded Rubber Bushing, Replacing
5 Wheel Bearing
5.1 Overview - Wheel Bearing
5.2 Wheel Bearing Housing, Removing and Installing
5.3 Wheel Bearing Unit, Removing and Installing
6 Drive Axle
6.1 Overview - Drive Axle
6.2 Overview - Drive Axle
6.3 Drive Axle, Removing and Installing
6.4 Drive Axle Threaded Connection, Loosening and Tightening
6.5 Drive Axle Heat Shield, Removing and Installing
6.6 Drive Axle, Disassembling and Assembling
6.7 Outer CV Joint, Checking
6.8 Inner CV Joint, Checking
7 Special Tools
42 - Rear Suspension
1 Rear axle
1.1 Overview - Rear Axle
1.2 Rear Axle, Lowering
1.3 Rear Axle, Removing and Installing
1.4 Rear Axle Trim Panel, Removing and Installing
2 Axle Beam
2.1 Overview - Axle Beam
2.2 Axle Beam Bonded Rubber Bushing, Replacing
3 Subframe
3.1 Overview - Subframe
3.2 Overview - Subframe Attachment
3.3 Subframe, Securing
3.4 Subframe, Servicing
4 Stabilizer Bar
4.1 Overview - Stabilizer Bar
4.2 Stabilizer Bar, Removing and Installing
4.3 Coupling Rod, Removing and Installing
5 Control Arm, Tie Rod
5.1 Overview - Transverse Link
5.2 Overview - Tie Rod
5.3 Upper Transverse Link, Removing and Installing
5.4 Lower Transverse Link, Removing and Installing
5.5 Tie Rod, Removing and Installing
6 Suspension Strut, Shock Absorber, Spring
6.1 Overview - Suspension Strut, Shock Absorber, Spring
6.2 Shock Absorber, Removing and Installing
6.3 Shock Absorber, Servicing
6.4 Spring, Removing and Installing
7 Wheel Bearing and Trailing Arm
7.1 Overview - Wheel Bearing
7.2 Overview - Trailing Arm
7.3 Wheel Bearing Housing, Removing and Installing
7.4 Wheel Bearing Unit, Removing and Installing
7.5 Wheel Bearing Housing Bonded Rubber Bushing, Replacing
7.6 Trailing Arm with Mounting Bracket, Removing and Installing
7.7 Trailing Arm, Servicing
8 Drive Axle
8.1 Overview - Drive Axle
8.2 Drive Axle Threaded Connection, Loosening and Tightening
8.3 Drive Axle, Removing and Installing
8.4 Drive Axle, Disassembling and Assembling
8.5 Outer CV Joint, Checking
8.6 Inner CV Joint, Checking
9 Special Tools
43 - Level Control System
1 Electronic Damping
1.1 Overview - Electronic Damping
1.2 Electronic Damping Control Module J250, Removing and Installing
1.3 Left and Right Front Body Acceleration Sensor G341/G342, Removing and Installing
1.4 Rear Body Acceleration Sensor G343, Removing and Installing
2 Level Control System Sensor
2.1 Overview - Front Level Control System Sensor
2.2 Overview - Rear Level Control System Sensor
2.3 Left and Right Front Level Control System Sensor G78/G289, Removing and Installing
2.4 Left and Right Rear Level Control System Sensor G76/G77, Removing and Installing
3 Special Tools
44 - Wheels, Tires and Wheel Alignment
1 Axle Alignment
1.1 Axle Alignment Information
1.2 Test Requirements
1.3 Measurement Preparations
1.4 Axle Alignment Specified Values
1.5 Axle Alignment Procedure
1.6 Need for Axle Alignment, Evaluating
1.7 Vehicle Data Label
1.8 Front Axle Camber, Adjusting
1.9 Rear Axle Camber, Adjusting
1.10 Rear Axle Toe, Adjusting
1.11 Front Axle Toe, Adjusting
1.12 Wheel Run-Out Compensation
1.13 Maximum Steering Angle, Checking
2 Adaptive Cruise Control (ACC)
2.1 Adaptive Cruise Control (ACC), Calibrating
3 Driver Assistance Systems Front Camera
3.1 Driver Assistance Systems Front Camera, Calibrating
4 Special Tools
48 - Steering
1 Steering Wheel
1.1 Overview - Steering Wheel
1.2 Steering Wheel, Removing and Installing
2 Steering Column
2.1 Overview - Steering Column
2.2 Steering Column, Checking for Damage
2.3 Steering Column, Handling and Transporting
2.4 Steering Column, Removing and Installing
2.5 Electronic Steering Column Lock Control Module J764, Removing and Installing
3 Steering Gear
3.1 Overview - Steering Gear
3.2 Steering Gear, Removing and Installing
3.3 Boot, Removing and Installing
3.4 Tie Rod, Removing and Installing
3.5 Tie Rod End, Removing and Installing
3.6 Steering Gear, Servicing
4 Sensors
4.1 Steering Angle Sensor G85, Removing and Installing
5 Special Tools
